Roll Cage, Back Bracing |
Randal |
Feb 2 2009, 08:18 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
What is the minimum amount of bar that would need to be added from the back towers to the transmission cross member? Understanding that I am running a bar from the back hoop of the cage to the shock tower.
Could I just run a bar from a plate on the rear side of the shock, midway to the top of the transmission cross member? Just a simple triangle. Would that help? Picture below. |
koozy |
Mar 6 2009, 11:20 AM
Senior Member Group: Members Posts: 651 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
Sounds cool. I just got word on my car. I'll be picking it up on Monday. I'll have plenty of work to do before I'm ready for any fab, but this car should be ready and tested before the shootout. It may not be completely sorted by then, but close.
Randal |
Mar 6 2009, 02:38 PM
Sounds cool. I just got word on my car. I'll be picking it up on Monday. I'll have plenty of work to do before I'm ready for any fab, but this car should be ready and tested before the shootout. It may not be completely sorted by then, but close. It takes a ton of time to sort out cars Mike. You ought to put a plan together on how you want to start testing your car, but first all those things you want to change before day one, i.e., all front and rear suspension components and settings, cage, tires and (very important) lowering and alignment. Probably the biggest part of the sort out is the iterative process the driver has to go through to understand what needs to be changed. |
Lo-Fi Version | Time is now: 27th September 2024 - 07:49 AM |
