How low...can you go. And how did you do it? |
ottox914 |
Mar 2 2009, 09:55 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Thinking of lowering the 914 some more. I should be getting the new turbo motor done. 2 seasons ago I had it REAL low, so low that, while on a smooth auto cross course, the front "A" arm did not hit the pinch weld on the tub, but on the road, a good bump would = a big clunk. I confirmed this by putting some tape on the "A" arm and seeing it damaged, proved my theory. A little to low. I know if you go super low, the camber curve gets out of whack. I liked the look of the car lower, and it seemed to handle well also. I'd consider making a new lower "A" arm, but was wondering what I could learn from those who have been there/done that. I'm running a SA koni insert in front from something or other, that Jason Burkett from Paragon sold me, I needed to shorten the strut tubes about 5/8" to make them fit. The front is now low enough such that with the Koni snubbers, and a zip tie on the shock shaft, that during normal driving I have maybe 1/4' to the snubber. Rear ride height is currently set off the front, to achieve best possible corner balance/cross weights. As the Koni's are several seasons old, I'd not be adverse to sending them in for a re-build, and having them shortened, F and R. Anyone convert the rears to use a more commonly available "eye" style shock? Show me that too...
thanks- |
bam914 |
Mar 13 2009, 08:00 PM
Member Group: Members Posts: 342 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None |
I am getting shorter eyelets. It is about 2.5". It should be enough.
Lo-Fi Version | Time is now: 27th September 2024 - 09:06 AM |
