Advice for adding a "wevo type coupler" to a 914 |
computers4kids |
Apr 25 2009, 02:39 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I would like to add a 360 degree rotational coupler in place of the stock coupler found on the shift rod near the firewall. With my v8 conversion the fan belt is very close to the stock coupler when the shifting in 4th and 5th gears.
Looking for any advice or source for such a coupler and install tips. (IMG:http://www.914club.com/bbs2/uploads/post-2837-1155654490.jpg) This picture is not of my v8, but it illustrates how close the coupler is to the belt. The coupler when turned by the shift rod used to barely clear, but now since I lowered my car...the coupler grazes the belt on 4th and 2nd gear shifts...too close for my comfort. (IMG:http://www.914world.com/bbs2/uploads/post-159-1154282960.jpg) |
john rogers |
Apr 25 2009, 08:51 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I have had one on my race car for probably 8 or 9 years I figure by now. They eliminate a tremendous amount of slop that you never realize is actually there until it is gone. I have mine welded to the rear shift rod and drilled/tapped for a factory pinch screw in the front half. I used some heat absorbing stuff when welding the rear on so the rubber boot would not melt.
When I installed it, I made the drilled and tapped hole and mounted the front of the coupler and the rear joint was a snug fit so I just made it up like it would be permanate and tack welded it. I took the rear shift rod off for finish welding. |
Lo-Fi Version | Time is now: 23rd November 2024 - 01:23 AM |
