Judging Interest for LOW flexible front spoiler |
VaccaRabite |
Feb 27 2009, 08:04 AM
En Garde! Group: Admin Posts: 13,553 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Last week I approached Mikey914 about making a flexible front spoiler similar to the NLA Flexdam. He went to Camp see what I was on about, and noted that it was fiberglass and rubber and asked Morph about making the glass part.
Verdict: it can be done. But, is there interest? This is what we are talking about: (IMG:http://www.pelicanparts.com/catalog/images/John1/914_rubber_spoiler.jpg) So. Are we interested in such an item? Cost would likely be in the $110 to $120 range, depending. You would get all the benefits of a really low spoiler, without the worry of killing it on the street every time you approached a speed bump or random twig or driveway. As a car moves swiftly down the road, air does under the body of the car as well as over the top, which produces lift. A low air dam blocks that airflow, and helps keep the car attached to the road at speed. Plus, they look cool. So. Who wants one? |
Mikey914 |
May 2 2009, 10:41 PM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
You are correct it does keep air from getting under the car. The lower pressure should also apply some downforce, like a wing only upside down. The drawback is the greater the low pressure, the more warm air that gets trapped, increasing running temps. So there will be some trial and error as to the temps your running. As there are different size motors and some cooling systems (read oil coolers) are in better shape there is no set opening size that can be cut into the rubber. It's a matter of checking your temps as you run and openig up as you need to.
The fiberglass portion will be out on Monday, the rubber is about 4 weeks out still. I'll be posting on Monday. |
Lo-Fi Version | Time is now: 27th September 2024 - 06:34 AM |
