Electrical Question, Hot in Run and Start? |
andys |
May 7 2009, 02:59 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
On my V8 conversion, I need two hot in run and start +12v sources, but I'm not sure how to determine this from any of the 914 diagrams. I need to power up my PCM, and an Accusump solenoid (or maybe just one hot to activate a relay for both?).
Many thanks, Andys |
SLITS |
May 7 2009, 04:20 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
It is switched power ... on when the key is on ... moving the key to start does not shut the power off on a switched power circuit
You asked for a source of 12 VDC in start only and 2 in run .... I gave you the pinouts for both. |
andys |
May 7 2009, 04:30 PM
It is switched power ... on when the key is on ... moving the key to start does not shut the power off on a switched power circuit You asked for a source of 12 VDC in start only and 2 in run .... I gave you the pinouts for both. Thanks Ron. "It is switched power ... on when the key is on ... moving the key to start does not shut the power off on a switched power circuit" That's pretty much what I needed to know. On many newer cars, a lot of un-necessary circuits are off in start then returns to on in run. I suspected (but wasn't sure) that the 914 is the old school type. Andy |
Lo-Fi Version | Time is now: 26th September 2024 - 11:17 PM |
