REPLACE YOUR FUEL FILTERS !, in and out sides? |
jimkelly |
May 25 2009, 08:48 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
do i have this marked correctly or reversed?
pic replaced with new pic reflcting slits comment Attached image(s) |
jimkelly |
May 25 2009, 10:08 AM
that is weird - the fuel comes out of the tank and to the filter in small ID hose - then from fuel filter to fuel pump in large ID hose - then from fuel pump to engine bay in small ID hose.
why the diameter changes? advanced auto had to order my filter - should be here tomorrow. jim |
SLITS |
May 26 2009, 08:01 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
that is weird - the fuel comes out of the tank and to the filter in small ID hose - then from fuel filter to fuel pump in large ID hose - then from fuel pump to engine bay in small ID hose. why the diameter changes? advanced auto had to order my filter - should be here tomorrow. jim Electric fuel pumps are "pushers" not suckers, which is why they are properly mounted below the fuel level to flood the suction of the pump, much like a /6 oil pump .... flooded suction. So, in theory, a large suction line (no pressure) can morph to a small line (pressure). However, that stated, the '75 - '76 had the same size suction and discharge -- go figure, only the engineers know. And the filters I use have 7mm in and out ..... not a problem as far as I am concerned ... inexpensive too! |
Lo-Fi Version | Time is now: 26th September 2024 - 09:48 PM |
