Impossible to balance wheel ... two shops already failed ..., New tyres didn't help ... |
johannes |
May 28 2009, 07:31 AM
Club Porsche 914 France President Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
I bought a set of Mahle with tyres.
I brought them to a shop to have them balanced. When I put them on the car it started to vibrate at 90 to 120 kmh (55 to 75 Mph) Brought it back to the shop, redid the balance, didn't help. They say, the tyres may be warped. I bought them a new set of tyres, let it balance ... didn't help. They sent me to another shop that has a better machine. They put (a lot of)weigths inside and outside the rim (ugly), but it didn't helped. The problem occured when I bought these rims I figure they may be bent ... Could this old and wise guy be right ? http://www.youtube.com/watch?v=PeclYZQCyso Any advices ... |
Katmanken |
May 28 2009, 08:24 AM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
First, I'd loosen the lug bolts and properly retorque the wheels onto the car with the cross torque sequence. Shops use high power air tools and when they don't use the cross torque sequence, can bend the wheel. Sometimes loosening and retightening the lug bolts solves the problem
You need to measure the rims to see if they are bent. You can do this on the car by jacking up one wheel so it doesn't touch the ground and spinning the wheel while measuring the rim movement. Two possible rim movements. If it's bent from a side hit, face the wheel like you want to remove the lug bolts. Place a dial indicator at the edge of the rim so that the probe of the indicator is parallel to the axle and touching the edge of the rim next to the tire. Spin the wheel. If the rim is bent, the probe of the indicator will move in and out along the axis parallel to the axle. The other bend to a rim comes from a front impact such as a curb or pothole. In that case, the rim is no longer round and a dial indicator can also tell. Sometimes you get both. If the rims are OK, it's probably the tires. |
Drums66 |
May 28 2009, 02:14 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
First, I'd loosen the lug bolts and properly retorque the wheels onto the car with the cross torque sequence. it's probably the tires. I think this is your problem (IMG:style_emoticons/default/idea.gif) this has happened to me before! (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 01:17 PM |
