Impossible to balance wheel ... two shops already failed ..., New tyres didn't help ... |
johannes |
May 28 2009, 07:31 AM
Club Porsche 914 France President Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
I bought a set of Mahle with tyres.
I brought them to a shop to have them balanced. When I put them on the car it started to vibrate at 90 to 120 kmh (55 to 75 Mph) Brought it back to the shop, redid the balance, didn't help. They say, the tyres may be warped. I bought them a new set of tyres, let it balance ... didn't help. They sent me to another shop that has a better machine. They put (a lot of)weigths inside and outside the rim (ugly), but it didn't helped. The problem occured when I bought these rims I figure they may be bent ... Could this old and wise guy be right ? http://www.youtube.com/watch?v=PeclYZQCyso Any advices ... |
Downunderman |
May 28 2009, 02:39 PM
Senior Member Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
Are the front wheel bearings properly adjusted so there is no slop?
aircooledtechguy |
May 28 2009, 03:31 PM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
Are the front wheel bearings properly adjusted so there is no slop? (IMG:style_emoticons/default/agree.gif) I had a high-speed shake when I first bought my car and this is exactly what is was. Anyone here use balancing beads?? I used these on my wife's minivan and they work incredibly well and the tires are wearing VERY evenly (well as evenly as they can with Ms. Andretti at the wheel). The 914 will get them when I up-grade the tires. |
Bartlett 914 |
May 28 2009, 05:12 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Anyone here use balancing beads?? I used these on my wife's minivan and they work incredibly well and the tires are wearing VERY evenly (well as evenly as they can with Ms. Andretti at the wheel). The 914 will get them when I up-grade the tires. Sorry for the hijack but the beads look interesting. If these work and fit through the valve stem, why wouldn't small steel balls work? |
aircooledtechguy |
May 28 2009, 06:09 PM
Anyone here use balancing beads?? I used these on my wife's minivan and they work incredibly well and the tires are wearing VERY evenly (well as evenly as they can with Ms. Andretti at the wheel). The 914 will get them when I up-grade the tires. Sorry for the hijack but the beads look interesting. If these work and fit through the valve stem, why wouldn't small steel balls work? I know a guy who used high density air-soft BBs with equally good results. He just used 3 oz in each wheel (popped the bead on one side and poured them in). He was out the door with perfectly balanced tires for about $7 from WalMart. . . Your tires sweat on the inside as they get cold and hot, so steel BBs will tend to rust and go away over time. 'Course it would likely take a long time and you'd likely need new tires before that happens. I do balancing on my restoration cars with these since it's cheap and allows you to not have to run ugly weights on restored wheels that can come off and ruin the finish. |
VaccaRabite |
May 29 2009, 10:31 AM
En Garde! Group: Admin Posts: 13,554 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Anyone here use balancing beads?? I used these on my wife's minivan and they work incredibly well and the tires are wearing VERY evenly (well as evenly as they can with Ms. Andretti at the wheel). The 914 will get them when I up-grade the tires. Sorry for the hijack but the beads look interesting. If these work and fit through the valve stem, why wouldn't small steel balls work? I know a guy who used high density air-soft BBs with equally good results. He just used 3 oz in each wheel (popped the bead on one side and poured them in). He was out the door with perfectly balanced tires for about $7 from WalMart. . . Your tires sweat on the inside as they get cold and hot, so steel BBs will tend to rust and go away over time. 'Course it would likely take a long time and you'd likely need new tires before that happens. I do balancing on my restoration cars with these since it's cheap and allows you to not have to run ugly weights on restored wheels that can come off and ruin the finish. Steel looses its roundness quickly, due to rust. Once it stops being round, it stops working. And it also starts wearing the interior of the tire, which could lead to premature failure. beads don't work if they clump in the wheel. they need to flow to the point of imbalance. 4x4 guys use balance beads all the time, as those big tires are a total bitch to balance. For my m715 with 38inch tall TSL mudders, the shop would not even try to balance the wheels and told me to get ceramic beads, 10 OZ in each wheel. (my tires are WAY bigger then 914 tires, though....) Zach |
Lo-Fi Version | Time is now: 27th September 2024 - 01:16 PM |
