Tips for removing shift rod from shift rod head?, BFH? |
wobbletop |
Jun 20 2009, 07:28 PM
Member Group: Members Posts: 382 Joined: 8-December 06 From: Ontario, Canada Member No.: 7,335 Region Association: Canada |
Hi,
The plastic cover for my side shifter linkage is not installed. To install it, I need to separate the shift rod from the shift rod end. Separate #27 from #24 in this diagram... (IMG:http://www.pelicanparts.com/914/Parts/Pedals/shift_linkage_side_big.jpg) Any tips? I have the tapered screw out (#23), but the two pieces seem very tightly joined. I have searched, but most refer to the joint close to the firewall. Will I be able to replace the plastic cover with just this joint removed, or will I need to take off the firewall joint as well. Thanks, Walter |
Dr Evil |
Jun 22 2009, 12:13 PM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
You can use heat as well, but make sure the surface is relatively clean so you dont start a class B fire (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 27th September 2024 - 02:03 PM |
