914/6 axles questions |
Project 6 |
Jun 23 2009, 09:19 AM
large member Group: Members Posts: 359 Joined: 30-December 02 From: Utah Member No.: 51 Region Association: None |
OK, so I'm ready to install the engine and found a surprise. The PO was going to install a later model trans. As such, they installed 915 style stub axles. The oem stubs are lost in space.
The existing stubs don't bolt up to the 914/4 axles and CVs I was going to use. The 2.0/6 "S" spec motor puts out about 140hp. So I wasn't worried about twisting them with high torque since I used this set up with a 3.0 in the past. My questions is....are 914/6 AXLES which I might have access to, compatible with 915 sized CVs? FYI 914/6 CVs have been NLA for 20+ years.... Since I have the sub axles, can easily find drive flanges for the trans, I was thinking this would be an easy alternative. Does the 914/6 axle have the same spline count? 28 is what I've been told. Simply using a 911 axle won't work, too long. Buying 914/6 stub axles is an expensive deal, $5-600. Mittelmotor and Otto.... Some good news, I HAVE been able to locate one stub axle...it will need a little machining as it's a bit corroded. But I'm looking for alternatives. Anyone BTDT? Or even better....an orphan 914/6 stubbie? |
SLITS |
Jun 23 2009, 11:12 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Ok Mike,
I have our axle supervisor looking to see if any of the early 911 CVs we have have the stub axles still attached. Most of the time they are removed. Will let you know ........... |
Lavanaut |
Jun 23 2009, 12:34 PM
Hungry Mind : Thirsty Gullet Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
I have our axle supervisor looking to see if any of the early 911 CVs we have have the stub axles still attached. Most of the time they are removed. After reading the original post a few times trying to understand the issue, it sounds to me like he's already got the 911 stub axles and tranny flanges. The issue is the 911 stubs won't mate to the stock 4-cylinder CVs (true), and the question is, will a 914-6 axle mate to 915 CVs? Right? I don't know the answer to that question. What I do know is that Sway-a-Way makes the axle you need if the 914-6 axle doesn't pan out. Of course if you can find another 914-6 stub, that's the easiest way to go. Reid |
Lo-Fi Version | Time is now: 27th September 2024 - 12:57 PM |
