Pin holes in the head sealing surface..., Can I run as-is, or should they be welded up? |
jhadler |
May 15 2009, 11:21 AM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Hey all,
The motor is going back together, and upon close inspection of the heads, there are some small pinholes along the sealing surface of the head. I'd like to drop the head gasket and lap the cylinder to the head, but will these holes be a problem? Based on the measurements, the pinholes will be 0.016" outside of the ID of the jug, and as such, covered by the jug. But is that enough? Can I run this as-is? Lap the jugs to the heads, and run sans gasket? Should I run I gasket? Or should I have the holes welded up and re-flycut the heads? There's all of about 40 minutes run time on these heads right now. Thoughts? Experience? Thanks! -Josh2 |
VaccaRabite |
Jul 1 2009, 06:12 AM
En Garde! Group: Admin Posts: 13,553 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Just to be sure you are clear on this. The rings between the block and the cylinders are shims, NOT gaskets, and you need them to get your target CR.
The rings between the cylinders and the heads ARE gaskets. Running them or not is a source of debate, but I don't. Zach |
Lo-Fi Version | Time is now: 26th September 2024 - 09:56 PM |
