Rear Bumpertops Finally! After alot of trial and error, Prepurchse closed |
Mikey914 |
Sep 27 2009, 11:59 PM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
For those of you that hjave been following the production of the rear tops, I have finally got all the bugs worked out. I kept having the interal stainless structure blow into the top edge at the licence plate wells. I'm having to play with the water jet cutter to make the shape I need to make this work correctly. These do have the suport running from the edge mounts through the center mount so the section will not droop where the licence plate goes.
After the run is started these will go to $286 Who needs one? Don't need money now, just a list of those that will be needing them, I'll forward out the payment specifics later. Attached thumbnail(s) |
SUNAB914 |
Sep 28 2009, 12:55 PM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
Are you still selling the front ones, if so how much?
Thanks |
Mikey914 |
Sep 29 2009, 01:03 AM
Are you still selling the front ones, if so how much? Thanks Yes I am. I have them listed in member vendors, and on the original thread. http://www.914world.com/bbs2/index.php?sho...c=94554&hl= Thread http://www.914world.com/bbs2/index.php?showtopic=91029 Member vendor's section with seal prices too. PM me if you need more info, there's alot of info on the thread. Thanks, Mark AKA Mikey914 |
Lo-Fi Version | Time is now: 27th September 2024 - 04:34 PM |
