Question about the fuel line in the tunnel, what does the original look like? |
dkos |
Nov 16 2009, 02:59 PM
say, "RUST"! Group: Members Posts: 295 Joined: 1-December 04 From: Philadelphia, PA Member No.: 3,204 Region Association: None |
How can I tell if the tunnel fuel lines have already been replace? Someone messed around with something in my tunnel. There is a large opening cut in the top of the tunnel near the front of the car and the existing service opening in the rear of the tunnel has been "expanded". The firewall in the engine compartment where everything comes out of the tunnel looks messed with too...tho it's hard to tell because it's so gooped up with undercoating.
It looks and feels like the lines in the tunnel are copper coming in from the engine compartment side, but somewhere near the front of the tunnel they feel like they turn into plastic (or rubber). It feels like a very smooth transition...almost like the tubes were butted up against each other and taped! The plastic tubes feel smooth and solid and flexible...not brittle. What were the original fuel lines like? |
underthetire |
Nov 16 2009, 04:25 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Someone put brake line tube in. Most SS, and all copper is non-magnetic. Brake line is usually plated with a wierd green coating.
dkos |
Nov 16 2009, 04:34 PM
Someone put brake line tube in. Most SS, and all copper is non-magnetic. Brake line is usually plated with a wierd green coating. Interesting. Maybe I'm looking at the wrong lines in the rear of the tunnel. I've color keyed the picture of the tunnel. The pink is the fuel line, right? What's the green? While we're at it what are the others? Attached thumbnail(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 06:24 AM |
