Powered washer fluid assembly |
swood |
Nov 29 2009, 07:40 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Ok, so I'm mocking up what I have for this assembly and referencing Andy's write up
I have a few questions and I'll post a few pics. First, when I pulled out the filler tube, it basically crumbled on me. All I have at the moment are zip ties, but here's my modification. I suppose by the time I power it up, if it leaks I can get a better hose clamp. By bypassing the spare tire connection, I can run this tubing right to the pump itself. Can I mount my pump in this area? I have a new Bosch relay p/n # 0 332 019 150-010. It looks like it would go here. No clue on how to wire to it yet. |
flipb |
Nov 29 2009, 08:54 PM
Senior Member Group: Members Posts: 1,754 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
Has anyone ever stuck with the stock setup but added something other than the spare tire to pressurize the tank? I don't know what... weak electric air pump? CO2 canister?
I guess that wouldn't eliminate (heck, would probably increase) the chances of douching yourself when you pull the stalk. But somehow seems a little more true to the original engineering. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:35 PM |
