preserve your Rubber with this stuff... |
ME733 |
Nov 7 2009, 02:32 PM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
(IMG:style_emoticons/default/popcorn[1].gif) ....Well I was fortunate some few years ago to luck up on a no-brand silicone liquid that was like molassis...used it for every rubber part on my cars until it was gone......AND I HAVE FOUND....a product you need to be aware of a product I just discovered. I think It,s new on the market....here goes ...BLACK MAGIC -Titanium....it,s a tire shine product...Its a THICK silicone,almost a gel, and comes with a scrub brush applicator. This stuff is INCREDABLE. I scrubbed down my tires (washed them) several times,allowed them to dry, and in the warm sun applied this stuff to both sides of the tires. They look better than new....Then I started on the rubber bumper tops, and every other rubber part on the car.(914)...it,s been about 3 weeks since I treated the whole car, and the rubber everywhere looks just great!!!...I got clean rags, wiped down most of the rubber parts, which released the imbeded dirt and crud from the rubber. then reapplied it everywhere again. ALL this took about 1/4 of the bottle, which is 16 oz,s. This stuff really works, It soaks into the rubber making it softer, looks great and will last longer than anything I have ever used... (IMG:style_emoticons/default/popcorn[1].gif)
tod914 |
Dec 7 2009, 09:16 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Pat to clairify, it was the black coating put on either by the dealer or the factory as an option, after the paint. Have to get a COA to determine who did it. It's certinaly not the Ziebart that's on there. I'll try to get some shots so you see what I mean. I guess it's possible it's tar, but seems to be more of a rubbery compound.
Pat Garvey |
Dec 14 2009, 08:41 PM
Pat to clairify, it was the black coating put on either by the dealer or the factory as an option, after the paint. Have to get a COA to determine who did it. It's certinaly not the Ziebart that's on there. I'll try to get some shots so you see what I mean. I guess it's possible it's tar, but seems to be more of a rubbery compound. Tod, A COA will probably NOT list any rustproofing, factory or dealer. So, let's get the the facts together on early '70's Ziebart. That way, we can segregate the Ziebart from the factory coatings. Ziebart was tar-based. May have had some wax tossed into it also, but I don't know. What I do know is that a Ziebart treated car had numerous holes drilled into body cavities and structiral parts, to allow spraying the compound into them. On a 914, these areas included: Rear door jambs Front and rear structural hood elements Sail panels Holes were drilled, sprayed into & then capped with plugs. The entire rest of the underbody was sprayed with the same substance. Most cars that have had the treatment still have it on suspension pieces, because the folks at Ziebart thought they were doing a good thing (which they were). Ziebart was not a fools folly - it worked, and still does today. Thiers was a well thought out process that actually helped protect cars, particularly in the rust belt of this country. Now, with that said, the factory wheel well coating was a Schutz compound, which is rubber based and paintable. Both compounds, after these many years, are renewable and paintable. See my earlier text on renewing. Now,the easy way to determine a Ziebart-treated car.......look for the yellow/black/red plastic plugs covering the drilled holes. Hope this helps. Pat |
Lo-Fi Version | Time is now: 27th September 2024 - 07:58 AM |
