case and head vents, do I need to run a breather box? |
wayne1234 |
Jan 22 2010, 11:23 PM
Member Group: Members Posts: 260 Joined: 6-April 09 From: indianapolis in Member No.: 10,238 Region Association: None |
Ok dual webber carbed 2.0, I think the PO had the head vents running to a T then to the oil breather near the oil cap... Is this right?? I did a search and now I'm really confused,,,,
HAM Inc |
Jan 28 2010, 08:58 AM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
QUOTE Now that the head guy spoke up and said it didn't do jack for the engine , I want to hear more of this new info please, Len ??? It does do something; it slows the return of oil to the crankcase and therefore the pickup and it causes the oil to run a bit hotter. I'm going to let you guys stew on this one for a while and see if you can figure it out. I'll give you a hint; it has to do with pressure differentials between the crankcase and rocker chambers. |
JFJ914 |
Jan 28 2010, 09:31 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
QUOTE Now that the head guy spoke up and said it didn't do jack for the engine , I want to hear more of this new info please, Len ??? It does do something; it slows the return of oil to the crankcase and therefore the pickup and it causes the oil to run a bit hotter. I'm going to let you guys stew on this one for a while and see if you can figure it out. I'll give you a hint; it has to do with pressure differentials between the crankcase and rocker chambers. So, I should just put pipe plugs in the holes you drilled and taped in the heads you built for me? I guess development marches on, my heads are still in the boxes after 3 years! Maybe this year! |
luvatenor |
Feb 1 2010, 09:49 AM
Newbie Group: Members Posts: 47 Joined: 20-December 09 From: NY Member No.: 11,154 Region Association: None |
QUOTE Now that the head guy spoke up and said it didn't do jack for the engine , I want to hear more of this new info please, Len ??? It does do something; it slows the return of oil to the crankcase and therefore the pickup and it causes the oil to run a bit hotter. I'm going to let you guys stew on this one for a while and see if you can figure it out. I'll give you a hint; it has to do with pressure differentials between the crankcase and rocker chambers. So, I should just put pipe plugs in the holes you drilled and taped in the heads you built for me? I guess development marches on, my heads are still in the boxes after 3 years! Maybe this year! Great info- Most of the info is for a two Carb setup. What about a single 2Bl Weber? Everything seems to have been removed from the engine compartment- just want to make it efficient and healthy- thanks |
Lo-Fi Version | Time is now: 27th September 2024 - 11:06 AM |
