Setting up to bench test 2.0 engine, Need some help with engine wiring |
LotusJoe |
Feb 18 2010, 09:43 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
I have built an engine stand for my 1973 2.0 engine. I'm in the process of trying to wire everything up to start the motor. Can anyone help me out with the what wires I need to supply power to the control module?
(IMG:http://photos-e.ak.fbcdn.net/hphotos-ak-snc3/hs180.snc3/20736_1346662951457_1377807605_959608_6834010_n.jpg) (IMG:http://photos-d.ak.fbcdn.net/hphotos-ak-snc3/hs200.snc3/20736_1346663111461_1377807605_959612_7956026_n.jpg) (IMG:http://photos-c.ak.fbcdn.net/hphotos-ak-snc3/hs180.snc3/20736_1346662991458_1377807605_959609_5643660_n.jpg) This photo show a small group of wires that plugs onto the module and then to (I think various locations on the engine). Looks like a pair goes to the back-up switch on the transmission, but I'm not sure about the rest of them. Any help is greatly appreciated Thanks Joe ( The Newbie to the 914 world) |
jcd914 |
Feb 19 2010, 11:13 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Here is what I have for the 14 pin connector for the Relay Panel.
1 - Power in from starter switch 2 - Power/ground for Alternator light 3 - 4 - 5 - From Oil Press Light 6 - 7 - Signal to Tach 8 - Power in from Ignition switch 9 - To Heater Fan Switch 10 - To Main Ground 11 - Power out to Heater Fan 12 - Power in from Battery 13 - Power out to Fuel Pump 14 - Power in from Battery Jim |
LotusJoe |
Feb 19 2010, 12:09 PM
Here is what I have for the 14 pin connector for the Relay Panel. 1 - Power in from starter switch 2 - Power/ground for Alternator light 3 - 4 - 5 - From Oil Press Light 6 - 7 - Signal to Tach 8 - Power in from Ignition switch 9 - To Heater Fan Switch 10 - To Main Ground 11 - Power out to Heater Fan 12 - Power in from Battery 13 - Power out to Fuel Pump 14 - Power in from Battery Jim Thanks Jim, that's exactly what I was looking for. Now I can finish the wiring for the engine stand. |
LotusJoe |
Feb 19 2010, 04:53 PM
Lo-Fi Version | Time is now: 27th September 2024 - 10:20 AM |
