Targa top not fitting in the trunk properly |
davesclassicvws |
Mar 8 2010, 09:42 AM
davesclassicvws Group: Members Posts: 82 Joined: 5-October 05 From: Camas,Wa Member No.: 4,917 Region Association: Pacific Northwest |
Awhile back I bought another targa top from Jamie (jrust). At that time I went through the top and replaced all of the seals and painted the top with a flat black. As I have been storing the top in the trunk on rides I recently notice the top is getting scratched just above the rear rubber hold down on the drivers side. I also notice that the trunk is not closing completely on that side.
The question is what do I look for and how do I fix it? It appears the hold downs are in the correct location and the trunk lid closes correctly without the top inside. I'll post some pictures later today. |
Tom_T |
Mar 8 2010, 11:59 AM
TMI.... Group: Members Posts: 8,320 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
In addition to centering the top in the clips ......
Check if the mount for the rear hold-down is bent or somehow out of alignment, &/or if the mount & rubber bit is/are installed properly. There is a bit of play & adjustment in them in most cases. Make sure the rubber hold-down hasn't cracked to allow the top to bounce. If not any of these, then ...... Also see if the rear lid is lifting at the front left corner - setting it out of kilter towards the rear - if so, then your hinge plate or roller/etc. up there has failed or is out of alignment. Likewise, check if the deck lid is somehow warped, bent, dented - which I'm assuming it isn't since you'd see that easily from the outside & think that you'd mention it here, but the inner brace(s) could be and be less noticeable. Also look to see if the top has an odd warp, but I doubt that cuz you'd probably notice it in difficulty securing the top to the cabin. If none of the above & if the car was in an accident or rust damage - either/both such that the rear end had some body work done on it & not fit up correctly &/or not Cellette Benched (or not done properly), then the uni-body could be out of whack. |
Lo-Fi Version | Time is now: 27th September 2024 - 08:40 AM |
