Update on the Compu-fire conversion, 2 week update |
underthetire |
Mar 11 2010, 12:27 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
My first ignitor was a Hot Spark, It looks and acts just like the Pertronix unit with the small magnet ring. Worked fine until I had a small melt down, not the hot sparks fault (IMG:style_emoticons/default/biggrin.gif) . What I had noticed since I use the megasquirt, and put my scope meter on it to confirm, is during cranking i never got a nice clean square wave signal out of it. Once started , it was fine. This time I opted for the Compu fire conversion, since this has a large disk that passes over the top of the sensor. The disk has small magnets on the outside edge, allowing a higher surface speed over the sensor. Cranking signal has cleaned up by a factor of 2 to 1. My idle is now way more solid than with the little ring magnet sensor type of pickup. So, in conclusion, the signal coming from the Compu-fire is much cleaner, allowing better idle control for my application. 2 weeks in so far. I obviously can not attest to longevity yet.
Either one IMO works well for carbs, or stock FI, but so far, I prefer the compufire for my aftermarket FI. Attached thumbnail(s) Attached image(s) |
ericread |
Mar 11 2010, 01:05 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Which Compufire unit did you install? The 21100 or the 21101? I am willing to try it on my daily driver.
Currently I user the Pertronix unit, but if you say I can get a more reliable spark, I'd like to try it. At 15,000 miles a year, it'll be easier for me to get real world reliability data. Eric |
Lo-Fi Version | Time is now: 27th September 2024 - 06:27 AM |
