1973 horn info, ok i'm confused.. |
buhs914 |
Mar 6 2010, 05:07 PM
Not So Newbie Group: Members Posts: 331 Joined: 16-June 09 From: Buckeye, AZ Member No.: 10,478 Region Association: Southwest Region |
So i bought a new low tone horn because the previous horn sounded like a miniature train. I thought it would be a direct swap until i found that it had these
they were powered by an air pump in the spare tire area that was wired to a relay right next to it.. WTF? i looked at the wiring diagram to see what wires actually go to the stock horn and i couldn't find those wires in my car.. i also find the wiring for the fog lights that i don't have (idk if those are supposed to be there or not).. could someone please post a picture of the stock horn with the wiring and relay. i need a reference. |
Mike Bellis |
Mar 11 2010, 10:54 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
If the PO added a Bosch type relay, take the wires from terminals 85 & 86 off the relay and put them directly to your stock horn. If you heard the relay "click" then the circuit is good and should sound your stock horn directly. Air Horns like what the PO added need the extra relay factory horns do not.
Lo-Fi Version | Time is now: 27th September 2024 - 07:47 AM |
