Fuel Line Replacement, What to use |
2-OH! |
Mar 5 2004, 11:05 AM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
I know we have covered this before but I can't find it in the classic threads...
What is the problem with using FLAPS "off the shelf" brake lines to replace "in Tunnel" fuel lines as long as it meets the I/D requirements... SS tubing is expensive but can be done through a local hose shop... 2-OH! |
Steve Thacker |
Mar 5 2004, 11:52 AM
UMMMPH Yea Baby Yea ! UMMMPH Group: Members Posts: 1,089 Joined: 8-January 03 From: Pickerington, Ohio Member No.: 113 Region Association: Upper MidWest |
I took some thick sheet rubber cut out little holders /seperators that go directly on the lines. They don't rattle anyway, but this helps keep them sort of centered in the tunnel and from rubbing each other. Use double clamps on the ends and you should not see a leak ever. Just take your time uncoiling them from the box and sliding them in through the tunnel and you should be good to go.
Lo-Fi Version | Time is now: 27th September 2024 - 12:46 PM |
