F^&*^&*^ing exhaust head studs- Distributor ?, My distributor is off 1/4 turn. How to fix? |
JRust |
May 1 2010, 04:18 PM
914 Guru Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay I officially pulled an dipshit move today. I was putting my drivetrain all together to be ready to install in my LE. All was going great as I had Mr Kona down helping me today. We got the transmission mounted. Put on the passenger side SS (bolted in place by Brian) & all was great. We change spots & I do the drivers side. I've got all the nuts on & am bolting into place. I have my torque wrench on there & am tightening away. It is was to big for the job but I figure all is well. Well I am a dipshit as I overtightened one & snaped the bolt (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) . I do have some nice stud pullers sowhile pissed for being an idiot. I figure I can get it out without to much trouble.
Hell no I can't. Even after some heat my stud snaps again at the head. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) . I then try to get under there & drill a hole to use an extractor. My extractor breaks in the hole I drilled. SO now I have to drill that out too. I am so frustrated & it's my own damn fault. I'm going to head to harbor freight & pick up a new tap & dye set. Any ideas on how to not screw this up any worse (IMG:style_emoticons/default/dry.gif) |
sww914 |
May 2 2010, 02:12 AM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
There is another way.
I've done it 100 times on various broken studs. With the head off you can put an 8mm nut on top of the broken stud and mig weld the nut to the broken stud, through the hole and fill the nut up all the way to the top. Hit it with an impact gun to unscrew the broken stud. Most likely it will just extract the broken easy-out so weld another nut on. It will probably break off so do it again. It will probably break off again so do it again. It might take 10 tries. Or 20. Each time the heat expands the stud and crushes the corrosion more than the last time, getting you closer to your goal. Even 30 8mm nuts are cheaper than a trip to the machine shop and cheaper than ruining your head with a drill bit drifting off to the side. Good thing steel mig welds won't stick to your aluminum head, isn't it? This process is so quick and easy if the part isn't upside down that I don't usually charge my customers to extract the broken fastener unless it's really bad. |
Lo-Fi Version | Time is now: 27th September 2024 - 05:09 AM |
