Boge strut insert questions |
kpfoten |
Jun 17 2010, 07:44 AM
Member Group: Members Posts: 220 Joined: 15-April 08 From: Escanaba, MI Member No.: 8,927 Region Association: None |
Hi--putting new Boge strut inserts in the front. The old ones didn't have any oil in the strut housing--should I put ATF in before I sink the new inserts in?
Also, I tried to extend the insert and put back up through the bushing and I can't seem to get it up there (the thing wants to contract)! Have tried a floor-jack, etc. I have the thought to get a long metric bolt that looks like it would screw into the top of the strut (the center is threaded) to help pull it through. Has anyone else had this problem? Oh, I guess I should mention that I didn't remove the strut housing to do all of this... |
jcd914 |
Jun 17 2010, 06:20 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
If it is just going to be a street car or daily driver (probably even an auto-x) I would not worry about adding oil to the strut housing.
The oil added to the strut housing helps the insert dissipate heat generated by the shock in motion. For a typical street car the shocks won't likely work hard enough long enough for heat to be an issue. For a track car the shocks may generate enough heat that the oil will help out. Of course if you have holes in the strut you don't have to worry about which choice you make. Jim |
Lo-Fi Version | Time is now: 27th September 2024 - 11:03 AM |
