914 w 911 SC motor, Spitting oil |
Nick |
Jun 19 2010, 02:36 PM
Member Group: Members Posts: 144 Joined: 25-June 04 From: Washington DC Member No.: 2,250 |
I have a 914 with fresh CIS 3.0 6 in it (less than 3k on rebuild). Due to travel etc I'm only driving it every 6 weeks or so. Every time I start it it smokes like crazy and some oil actually flows out of the tail pipe. Oil level is 2/3 of the way up between low and high marks. Took the air filter off to look for oil @ the air intake and did see a little as well as a small trickle of oil @ the top of the breather in the oil spout running back into the tank. Do I just need to keep the tank emptier?
If the car is driven 3 - 4 days in a row the symptoms go away |
rfuerst911sc |
Jun 19 2010, 04:15 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I have a 914 with fresh CIS 3.0 6 in it (less than 3k on rebuild). Due to travel etc I'm only driving it every 6 weeks or so. Every time I start it it smokes like crazy and some oil actually flows out of the tail pipe. Oil level is 2/3 of the way up between low and high marks. Took the air filter off to look for oil @ the air intake and did see a little as well as a small trickle of oil @ the top of the breather in the oil spout running back into the tank. Do I just need to keep the tank emptier? If the car is driven 3 - 4 days in a row the symptoms go away My 914 with a 3.0 and my 83 SC both blow smoke if I let them sit for a week or two it is normal. Conventional wisdom say's halfway up the dipstick is the proper oil level. Remember to check with motor warmed up and level with engine idling. |
Lo-Fi Version | Time is now: 27th September 2024 - 10:30 AM |
