914 w 911 SC motor, Spitting oil |
Nick |
Jun 19 2010, 02:36 PM
Member Group: Members Posts: 144 Joined: 25-June 04 From: Washington DC Member No.: 2,250 |
I have a 914 with fresh CIS 3.0 6 in it (less than 3k on rebuild). Due to travel etc I'm only driving it every 6 weeks or so. Every time I start it it smokes like crazy and some oil actually flows out of the tail pipe. Oil level is 2/3 of the way up between low and high marks. Took the air filter off to look for oil @ the air intake and did see a little as well as a small trickle of oil @ the top of the breather in the oil spout running back into the tank. Do I just need to keep the tank emptier?
If the car is driven 3 - 4 days in a row the symptoms go away |
GeorgeRud |
Jun 19 2010, 04:19 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
My six conversion will smoke like a mosquito fogger if it's been sitting for a long time, but runs great and doesn't use too much oil.
Check the oil level when warm and keep track of your consumption. One quart every 600 miles is even considered normal if I remember correctly, so they will use some oil. If you're not leaking oil or fouling plugs, you should be fine. |
Lo-Fi Version | Time is now: 27th September 2024 - 10:30 AM |
