914 w 911 SC motor, Spitting oil |
Nick |
Jun 19 2010, 02:36 PM
Member Group: Members Posts: 144 Joined: 25-June 04 From: Washington DC Member No.: 2,250 |
I have a 914 with fresh CIS 3.0 6 in it (less than 3k on rebuild). Due to travel etc I'm only driving it every 6 weeks or so. Every time I start it it smokes like crazy and some oil actually flows out of the tail pipe. Oil level is 2/3 of the way up between low and high marks. Took the air filter off to look for oil @ the air intake and did see a little as well as a small trickle of oil @ the top of the breather in the oil spout running back into the tank. Do I just need to keep the tank emptier?
If the car is driven 3 - 4 days in a row the symptoms go away |
eimc |
Jun 19 2010, 09:13 PM
Newbie Group: Members Posts: 45 Joined: 2-October 04 From: Mechanicsburg Penna. Member No.: 2,873 Region Association: None |
when you let it sit for a couple of weeks the oil seeps into the bottom of the crankcase (called wet sumping). If you have a drain plug on the engine(not the oil tank) drain the oil from the engine and pour it back in the tank. It should be only about a quart.
Lo-Fi Version | Time is now: 27th September 2024 - 10:36 AM |
