side mirror |
side mirror |
mipstien |
Jul 8 2010, 12:55 PM
Member Group: Members Posts: 261 Joined: 6-April 10 From: Maryville, TN Member No.: 11,576 Region Association: South East States |
i couldn't find any information on how to adjust or replace the side mirror and i didn't wanna just start unscrewing it incase those screws had bolts on the back and i lost those in the door panel when they fell.
do you just unscrew or do you have to take the panel off? mirror doesn't adjust because its rusted or too tight. |
plas76targa |
Jul 8 2010, 01:02 PM
Senior Member Group: Members Posts: 885 Joined: 22-February 04 From: Frederick, MD Member No.: 1,700 Region Association: MidAtlantic Region |
you can unscrew the screws. the 'nuts' they thread into are welded into the fender. (assuming you have stock mirrors)
once the mirror is removed turn it over and look down the 'barrel' there is a nut inside. remove that and the two half barrells, clean them all up with cleaner and perhaps a 3m pad. lubricate with a tiny amount of white lithium grease, reassemble and tighten nut just enough to allow adjustment moves. Re-install on door. my $.02 |
Lo-Fi Version | Time is now: 27th September 2024 - 06:24 AM |
