threaded bushing on Bilsteins doesn't fit? |
Jerry75914 |
Jul 27 2010, 11:29 PM
Member Group: Members Posts: 124 Joined: 13-October 08 From: Half Moon Bay, CA Member No.: 9,640 Region Association: Northern California |
Hi all,
I'm trying to put together my rear suspension. I have Bilstein HDs and Weltmeister 140lb springs. I removed the hat and related parts from my old assembly, and now I find that the threaded bushing is just too tight for the Bilstein. Anyone run into this? Do I need a different threaded bushing? Can I just run a slightly larger tap through it? It threaded about a third of the way before it was so tight I started stripping the hex head insert in the top of the strut...a totally differnt problem. Appreciate any advice! |
tradisrad |
Jul 28 2010, 11:33 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
Jerry, Are you talking about coil-overs not fitting? Or the nut that holds the strut in the car? I am not sure what the threaded bushing is.
-Rob (IMG:http://www.914world.com/bbs2/uploads_offsite/www.allshocks.com-6815-1280338681.1.jpg) |
Jerry75914 |
Jul 28 2010, 11:55 AM
Jerry, Are you talking about coil-overs not fitting? Or the nut that holds the strut in the car? I am not sure what the threaded bushing is. -Rob (IMG:http://www.914world.com/bbs2/uploads_offsite/www.allshocks.com-6815-1280338681.1.jpg) Hi Rob! It's the conical "nut" that holds the top hat looking gizmo on the coil. The nut that goes on last from the trunk is fine (came with the kit). |
Lo-Fi Version | Time is now: 27th September 2024 - 11:45 AM |
