Full flow oil system, is this bs or what? |
kdfoust |
Mar 21 2004, 03:47 AM
Senior Member Group: Members Posts: 694 Joined: 2-January 03 From: Riverside Member No.: 71 Region Association: Southern California |
I'll be getting my case back from RIMCO pretty soon and I'm thinking about the oil system. I'm planning to run a 30mm Schradeck (sp?) pump. I've read a number of threads about "full flow" oiling for TIV engines and I guess I don't get it.
For full flow on a TIV you do what? Plug or modify the oil filter bypass valve that I've circled below? Then what? Modify the oil pressure relief valve (new spring I guess) to accomodate higher pressure? Then what? At what pressure does the stock cooler blow open like a pan of Pop-Magic pop corn? TIA, Kevin Attached image(s) |
ThinAir |
Mar 21 2004, 08:04 PM
Best friends Group: Members Posts: 2,553 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
Kevin - That's the place! From the picture in the magazine it looks like they did more than just use a punch to close it up because the surface looks very smooth. Unfortunately the text I quoted previously is all they say about it and the web page about the project doesn't add any more (http://www.grassrootsmotorsports.com/914.html) I'm not sure where I saw something about just using a punch.
Lo-Fi Version | Time is now: 27th September 2024 - 02:15 PM |
