5 symptoms need help diagnosing, added a problem... probably culprit |
steveherman |
Oct 17 2010, 08:36 PM
Member Group: Members Posts: 380 Joined: 12-September 09 From: Kissimmee Florida Member No.: 10,799 Region Association: South East States |
Working on a 1974 2.0 d-jet
-symptom 1- when i start it... idle is very low no where near the 1600 rpm as Brad mentions -symptom 2- low idle...like 550 rpm -symptom 3- when coming to a stop it almost dies -symptom 4- stomp on gas when sitting and driving it goes blah... then takes off. -symptom 5- as it warms up loses a little power things to note: -there are 20 clicks when pushing down accelerator so tps is correct -timing and dwell were checked today and they were within spec. -lifters just adjusted |
Dr Evil |
Oct 20 2010, 06:47 AM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Not sure about the dizzy hoses, some one will chime in (I don't have a manual at work), but here are a few dx tools:
1) if adjusting the idle air bypass screw has no affect then you have a vacuum leak. 2) check your spark plugg, they will tell you if you are rich or not and will tell you if it is a setting issue ( all dark or light) or a focal issue (1 or 2 off color) |
Lo-Fi Version | Time is now: 27th September 2024 - 07:58 AM |
