3rd gear whine, 3rd is now spooling up.... |
stock93 |
Mar 24 2004, 04:38 AM
Member Group: Members Posts: 333 Joined: 12-May 03 From: Huntsville, AL Member No.: 684 Region Association: South East States |
I got to drive my car around for the first time today. I have a really loud whine from the transmission when in 3rd gear and under power. As soon as I let off power it stops whinning. It only does it in 3rd gear. What do you guys thing this would be? bearing? syncro? I'm definately not a transmission guy. I guess this would be a good time to switch to side shifter?
John |
JWest |
Mar 24 2004, 12:41 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
It does not really matter, as the side-shifter you get as a replacement could have the same issue. If you repair this trans you could still convert it to a side-shifter later without losing your new parts (the gears/bearings/syncros/shafts are the same between the two).
Lo-Fi Version | Time is now: 27th September 2024 - 02:15 PM |
