help with 3.2l conversion wiring, have a PMS 3.2l to 914-4 conversion cable but... |
jim912928 |
Dec 4 2010, 12:31 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Well, I have all of the mechanical work done for my 3.2l motronic conversion. Now I'm trying to figure out the wiring. I purchased the Patrick MotorSports conversion harness a few years back. It allows me to eliminate the relay board. However, electrical is not my forte...so I have some real questions on the "trunk" wires from the 3.2l harness and what to do with them. The engine, dme and wiring harness are all from the same car. So, here are my questions and you can relate them to the pictures as shown:
1. picture named "DME help" circle #1: by the dme connector...there are two little stub connections that seem to come out of the DME connector and both wires are brown....do these need to go to anything? 2. picture named "Trunk help" circle #2: I marked these fuel pump...do I cap these because I'm using the 914 wiring or do I need to connect them somewhere? 3. picture named "Trunk help" circle #3: I marked this positive battery...does the 914 harness cover this or do I need to connect it to the battery also? 3. picture named "Trunk help" circle #4: green and green/yellow wire...have no clue what this is? 4. picture named "Trunk help" circle #5: black wire by the wires I labeled "fuel pump"...have no clue what this is? 5. picture named "Trunk help" circle #6: white connector with a black, black/purple and yellow wire...have no clue what this is? I also would like to know where you usually mount the DME and where do you pass it through from the passenger compartment into the engine compartment..and once on the engine compartment side...where do you route it up to the engine? Have pics from those angles? Thanks all in advance! Jim DME help: Trunk help: |
shoguneagle |
Dec 9 2010, 03:50 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
Joe Sharpe did a great job on MoveQik's Sixer!!! It is one of the threads that needs to be read in detail.
The thread from the Pelican Board is a great one also, but it covers/indirectly sourced from Sixer conversions generally with excellent points, may refer to some elements for CIS which is a different animal than Motronics. Definitely a major detail read to understand. There are many other threads on these different boards covering the Sixer 3.2 conversion. They can be researched and studied in equal detail. They are excellent. Some names that popup are Summersled(?), A914Guy, MoveQik, Joe Sharpe, and many others which I did research several years ago. I cannot remember their names but they deserve the credit for providing quality information regarding the 914 3.2 engine conversion. Some more names are Sir Andy (3.6 conversion), McMark, Brad Mayeur; Yes, even Brad Roberts (disregarding the Politico Events, he really helped people including myself). Just so many who have done a great job in providing information so we can do our hobby, building Sixer 3.2 conversions. Enough said about that. There is information available from these different sources that should at least give a background in what has been used; and, the people who answered this thread as well as other historic contributors can give you information. Pelican Board has a very good general background paper and list of parts including what to generally look for during the conversion. There many pros and cons concerning such things as transmission to which MoveQik states and alludes to when using the 901 transaxle. I think the extra items which some of you are getting to can be readily provided but may be out of timing with this thread. I would like to keep the thread within the frame work of the electrical and problems surrounding it. Generally, we can give you whatever information that you need to get a valid pro and con using a one-on-one basis; or, we can undertake that information as everyone needs it. You have to participate in getting a background on this info since you will be the one doing the work (hopefully), and you can have understanding in what is going on within your electrical, fuel, etc. systems. Sorry I got long winded but the more you understand, the easier the conversion will be. |
Lo-Fi Version | Time is now: 27th September 2024 - 06:23 AM |
