2.0L prototype air intake parts in factory manual |
JeffBowlsby |
Dec 11 2010, 09:19 AM
914 Wiring Harnesses Group: Members Posts: 8,663 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Stumbled on this recently...how many differences can you see in this drawing, from what was actually produced? I count about 8. This is not the only prototype stuff in the factory manual. Thought some of you would find it interesting.
Attached thumbnail(s) |
sean_v8_914 |
Dec 11 2010, 10:43 AM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
1 filter housing size
2 shape 3 bolt down air cleaner no clips 4 wheres the air temp go? 5 no center stiffening tubes 6 box body is on the right instead of left or the whole thing is 180 clocked as it mounts to block 7 air bypass hole/adjuster 8 throttle body clocked 90 deg off, wheres the cable holder? 9 split down the vertical plane like a 1.7 OK Jeff, what differences did you not? htis was fun. |
Lo-Fi Version | Time is now: 27th September 2024 - 09:09 AM |
