CB rotary fuel pump failure, now it runs fine |
hydroliftin |
Jan 3 2011, 08:51 PM
Member Group: Members Posts: 378 Joined: 8-November 06 From: Vallejo, CA Member No.: 7,180 Region Association: Northern California |
New Year's day I went on a fun run with PCA. We drove a few hours through the Santa Cruz hills in light rain with the temperature in the 50's. I have a 2.0 liter with webers and the CB rotary fuel pump wired into the stock relay board as per the classics thread. The cover on the relay board is pretty good, I don't think it got wet. Over the course of the fun run I started and stoped the car several times with no problems.
On the way home, driving at the speed limit on Hwy 280 I start to lose power, the engine sputters and then dies. I pull to the side of the road, key the ignition and I can hear no fuel pump. I call the tow truck, and an hour later we drop my car off at the mechanic. I try to start the car again, still no sound from the fuel pump. The mechanic shows up a few hours later and the car starts fine. Monday morning, he trys again, same thing. Anyone have experience with CB rotary fuel pump failures? Seems to me they are pretty reliable from what I have read. Any suggestions as to what the problem might be? |
ME733 |
Jan 4 2011, 08:52 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
..........I have had problems with all of the high dollar rotery fuel pumps over the years., this is not to say they are no good, as they did give good service with accurete fuel pressure....Seems that the rotery pumps have such close tolerances that with even minor debris, such as fuel oxidation particles, etc, the rotors eventually sieze up. I have even had brand new pumps sieze up in just a few hours of use...The facet pumps make a lot of noise, but you cannot hear it with the engine running...they too will eventually fail, by "swetting" fuel and a lowering of fuel pressure as they age. Overall I prefer the facit for street use. A fuel pressure regulator is manditory. The key element to any fuel pump is to SOFT mount it in the chassis. I always used a rotery pump which had a pressure adjustment in the body and a water seperator for racing...as with anything mechanical nothing is forever.
Lo-Fi Version | Time is now: 27th September 2024 - 10:50 AM |
