Fan switch |
Fan switch |
partwerks |
Jan 6 2011, 07:38 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I had a custom aluminum radiator made and all the measurements look ok, except where the fan switch screws into the radiator and then the 2 wires for the fan plug into at.
I told the guy it was 3/4" but I believe he put in a 1" bung. My question is on the switch, on one side is stamped, 82/77 degrees C and the other side 2/5 I'm not sure what that translates to or if it is a rating that tells the fans when to come on and off at? I just need one size bigger with the same train of thought I guess? |
Spoke |
Jan 6 2011, 09:58 PM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
My question is on the switch, on one side is stamped, 82/77 degrees C and the other side 2/5 I'm not sure what that translates to or if it is a rating that tells the fans when to come on and off at? Does the switch have 3 terminals? The one from my Audi has a lower temp switch and higher temp switch. The lower temp switch turns the fans on at slow speed and if the radiator gets too hot, the higher temp switch turns on the fans at high speed. The switch for the Audi is 3/4 inch. |
Lo-Fi Version | Time is now: 27th September 2024 - 12:41 PM |
