ball joints, tips |
ball joints, tips |
tomh |
Feb 14 2011, 06:27 PM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
I want to do the ball joints while doing the sway bar because one of the rubber boots is torn.My question is after looking at the view of the front end in the Haynes book,whitch parts will i really need to do the job right?
detoxcowboy |
Feb 14 2011, 08:36 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
New Ball Joints (not sure what comes in the box..der I forgot) but you will need new ball joint threaded pins and lock nut ect.., they are not supposed to be reused.. her is a pic showing the washer but the pin and nut are pictured up close in the downloads, you failed to mention year of car or type of sway bar or what you doing with it..
911-341-119-06-M260 Threaded Pin, for Ball Joint Attachment (2 per car, sold individually) 914 1.7/1.8/2.0 (07/72-76), 914-6 (06/72 on), Each [More Info] Brand: OEM Ball Joint Mounting Hardware [view in catalog] $17.75 900-089-006-02-OEM Washer, for Ball Joint Threaded Pin (2 per car, sold individually) 914 1.7/1.8/2.0 (07/72-76), 914-6 (06/72 on), Each [More Info] Brand: Genuine Porsche Ball Joint Mounting Hardware [view in catalog] $0.75 999-084-019-02-M260 Lock Nut, for Ball Joint Threaded Pin (2 per car, sold individually) 914 1.7/1.8/2.0 (07/72-76), 914-6 (06/72 on), Each [More Info] Brand: OEM 3.bmp ( 129.13k ) Number of downloads: 71 untitled.bmp ( 129.13k ) Number of downloads: 60 |
Lo-Fi Version | Time is now: 27th September 2024 - 12:26 PM |
