914 four bolt pattern |
lmcchesney |
Apr 16 2004, 12:16 PM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
I have not found a complete source of accurate information on this topic.
The 914 is listed as having a 108mm four bolt pattern. What measures 108mm? The offset of my empi's are about 100mm. Is this the true specs? I have read else where that offset is a incorrect term. My use of offset is the distance from the inner surface of the wheel to the edge of the wheel rim projected down to the center line. Is this correct? Wheels are measured as 15 x 6.5. How do you measure the with of the rim? Is it from outer (curb surface) to outer or within the bead to bead? If you were to place your ruler on the rims, from what point to what point would you measure? What bolt dia and length and thread patern are standard? Ebay has a set of bolts that are 2 3/8" or 60mm in length and 1 1/2 inch or 36mm thead length. This allows about 50mm engaged inside the rotor hubs. What length should the bolts be inside the rotor hubs to be safely secured? Thanks, L. MCChesney |
lmcchesney |
Apr 16 2004, 01:25 PM
Phantom, is the 108, size of the imaginary circle. Do you mean the radius or diameter?
Dave, I have the Geoff not approved, 8 spoke Empi's as well with 205 on. Fit well when I had non flares. Now, Dave , you say it is a 4 x 130mm pattern. Is that 4 bolts, 130mm from center of hub to center of lug? Thanks L. Mcchesney Attached image(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 12:53 PM |
