Narrow and Broad band O2 sensors and open vs close |
lmcchesney |
Apr 16 2004, 05:15 PM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
Sorry guys, but I've been doing some reading again. Dave, you and I have had some of this discussion before and I would respect your continued thoughts on this setup. The crux of the matter requires understanding of the circuit utilized to turn the lamba analog data into useful information. Well, here goes.
O2 sensors in a distal position provides indirect input for the estimation of the A/F ratio seen by the engine. This information is useful in defining a lean or rich mixture seen by the sensor for the most recent peroid of time. Broad band O2 sensors are capable of producing a wide range of output voltages which can be inturpeted for measuring the ratio. In fact, the output from broad band sensors can be feed into the Electronic Control Unit several times a second. This allows for real time adjustment of the A/F mixture. Thus output from the O2 sensor is recieved as input by the ECU which inturn alters injector time/volume to preprogramed mixture. This feedback/adjustment defines a closed loop system. Narrow band O2 sensors also read A/F ratios. However, A/F mixtures ranging from 13.7:1 to 14.4:1 results in a change in voltage output from lowest to highest (0.1v to 1.0v). If you use a analog voltmeter or equalivernt A/F gague, the response rates are such that your readings bounce requiring seat of the pants estimate as to where the mean is. However, with the use of circuitry involving a IC unit, the voltage output can be lengthed to a series of LED's. My question, can not a narrow band O2 sensor be utilized to monitor A/F ratios throughout the power band. Noting the results, provide information for enrichment/leaning in the adjustable ranges of D-jet. ie, idle, partial throttle and WOT. Cannot in dash monitoring with such an A/F circuit be helpful to identify serious alterations in the engine and prevent damage from excessively lean running? Cannot the useful information from such an A/F monitor be inproved by silmiltaneous monitoring of CHT/oil temp? I still do not understand the advantages of a broad band O2 sensor when used in a open loop system. I cannot also see the significant advantage of a heated O2 sensor for monitoring the A/F ratios during that first 3 minutes. Thanks, L. McChesney Attached image(s) |
lapuwali |
Apr 16 2004, 05:32 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
First off, heated sensors aren't just useful during the first few minutes of operation. In order to be able to "read" all of the cylinders on most engines, the sensor has to be far enough away from the exhaust ports that it typically won't get hot enough (or stay hot enough) to read properly. Exhaust gas temp also changes pretty significantly based on load. One thing your included graph doesn't show is the response curve v. temperature. It changes quite a bit as the sensor temp changes. A heated sensor will maintain something close to the correct temp all the time. One of the aspects of the more complicated circuitry used to drive the wide-band sensor is temperature control, which has to be kept correct to a much higher degree of accuracy for the results to be at all meaningful. The narrowband sensor is less touchy, since it's response curve so non-linear.
13.7:1 and 14.4:1 probably isn't correct. Stoich is 14.7:1, and the sensors are biased around that figure. It's probably more like 14:1 to 15:1. Engines reliably operate over a range of about 11:1 to 17:1. For best power, you usually want a mixture in the 12:1 range. For best economy, you want it to be close to 16:1. Some specially designed "lean-burn" engines are designed to run at mixtures of 17:1-20:1, so they require a wide-band sensor capable of operating that lean. A narrowband sensor obviously won't operate out there, so the engine is restricted to running in a tight mixture range around stoich, which is the best compromise for emissions. It's quite common for ECUs (at least for pre-LEV cars) to go "open-loop" at or near full-throttle, to provide best power with a rich mixture that's beyond the range of the sensor. Running at 14:7:1 at full throttle is likely to cause lean engine failure over a long enough time, esp. for an aircooled engine. You can certainly use a narrowband sensor to tell you when something has gone wrong and your mixture has gone very lean or very rich. It's just not useful as a tuning aid if you're deliberately trying to make the car run at 12:1 or 17:1. |
Lo-Fi Version | Time is now: 26th September 2024 - 11:20 PM |
