914R build thread revisited, Latest transformation has commenced |
campbellcj |
Jul 2 2011, 04:23 PM
I can't Re Member Group: Members Posts: 4,588 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Some of you may have seen my earlier build thread on the 914club site. In a nutshell I have a 73 2.0 that I converted to a six in 2003. It's now heavily modified and race-prepped, powered by a stout 2.7 twin-plug engine.
The car currently weighs 1988lbs without fuel or driver; my POC minimum class weight with gas and driver is 2209lbs. It's still narrow-bodied and I am running 16x7 Fuchs with 205/45 Hoosiers. As you might guess, the car is significantly grip-limited and traction-limited in the rear especially. It basically tears the tread off R6's within 6 run sessions or so. Here is its current state: (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-21-1309645382.1.jpg) 914R at Streets of Willow by cjcam, on Flickr (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-21-1309645383.2.jpg) 914R at Willow Springs by cjcam, on Flickr I just dropped it off at a local shop, about to dive into: - Tangerine Racing steel flares, front/rear - Sheridan 6" f/g rear spoiler - Rollcage triangulation to suspension pickups - Possibly other chassis bracing - GT headlight lifts or remove lights completely - Repaint car (TBD how extensively) - RSR finish Fuchs 16x8's up front, 9's in rear - New graphics/decals One upcoming decision is whether to keep the sail vinyl or go body color without vinyl. I've always liked the factory vinyl and bright trim look but could go either way on this. The work could start as soon as Tuesday and I'll post updates and pics as I get them. This is not going to be a CW rotisserie sort of project since it's a race car, so progress should happen quickly and I plan to run the POC Laguna Seca event towards the end of August. Cheers, |
J P Stein |
Jul 9 2011, 09:56 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
The Fuch are light.....a bathroom scale will show that the 8 X 15 inchers are around 12 lbs ea. Those other things look heavy. In my experience to get a 16 incher that approaches those weights you need to go to a 3 piece wheel with a spun rim. My 10 X 16s weighed 11 lbs each but they are delicate....as tire mounters have found out.
Tis a slippery slope you are contemplating. Personally I go with 15 inch wheels, 8 inch in front & 10 inch in back. 225 X 45 & 275 X 35 tires they would keep the ride height down. The standard flares in back won't accommodate those rears but you have the HP to over power even those. OK, so I set up cars to suit available tires.....I've been on that slope. |
Lo-Fi Version | Time is now: 23rd November 2024 - 10:28 AM |
