914R build thread revisited, Latest transformation has commenced |
campbellcj |
Jul 2 2011, 04:23 PM
I can't Re Member Group: Members Posts: 4,588 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Some of you may have seen my earlier build thread on the 914club site. In a nutshell I have a 73 2.0 that I converted to a six in 2003. It's now heavily modified and race-prepped, powered by a stout 2.7 twin-plug engine.
The car currently weighs 1988lbs without fuel or driver; my POC minimum class weight with gas and driver is 2209lbs. It's still narrow-bodied and I am running 16x7 Fuchs with 205/45 Hoosiers. As you might guess, the car is significantly grip-limited and traction-limited in the rear especially. It basically tears the tread off R6's within 6 run sessions or so. Here is its current state: (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-21-1309645382.1.jpg) 914R at Streets of Willow by cjcam, on Flickr (IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.static.flickr.com-21-1309645383.2.jpg) 914R at Willow Springs by cjcam, on Flickr I just dropped it off at a local shop, about to dive into: - Tangerine Racing steel flares, front/rear - Sheridan 6" f/g rear spoiler - Rollcage triangulation to suspension pickups - Possibly other chassis bracing - GT headlight lifts or remove lights completely - Repaint car (TBD how extensively) - RSR finish Fuchs 16x8's up front, 9's in rear - New graphics/decals One upcoming decision is whether to keep the sail vinyl or go body color without vinyl. I've always liked the factory vinyl and bright trim look but could go either way on this. The work could start as soon as Tuesday and I'll post updates and pics as I get them. This is not going to be a CW rotisserie sort of project since it's a race car, so progress should happen quickly and I plan to run the POC Laguna Seca event towards the end of August. Cheers, |
campbellcj |
Jul 9 2011, 10:04 AM
With the Tangerine Racing flares, you are not adding or removing metal so there should be no drastic effect on weight. I went this route because I like the 'stealth' factory-like appearance of them, since they are reworked original steel vs. something obviously tacked-on. With this car I decided I did not want to cut-off the majority of the body and do something like a Sheridan kit or other total body replacement; although, I did think seriously about that.
tscrihfield |
Jul 9 2011, 11:09 PM
Drive Fast and Take Chances Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None |
Understood! I am a firm believer in you like what you like. Also, had no idea you were just working the original fenders... I am in even more anticipation to see it now! (IMG:style_emoticons/default/popcorn[1].gif) And I know what you mean about the wheel size, I can't go below 17inches because how far I lowered my spindles!
With the Tangerine Racing flares, you are not adding or removing metal so there should be no drastic effect on weight. I went this route because I like the 'stealth' factory-like appearance of them, since they are reworked original steel vs. something obviously tacked-on. With this car I decided I did not want to cut-off the majority of the body and do something like a Sheridan kit or other total body replacement; although, I did think seriously about that. |
Lo-Fi Version | Time is now: 23rd November 2024 - 10:20 AM |
