Relocate fuel pump, Where should it go |
Joe Ricard |
Apr 17 2004, 08:36 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
ANother since I'm in there and plan on replacing all the fuel lines anyway. Might as well move the fuel pump from the engine compartment to ?????? under the tank? In the car or under the car inside the splash shield? Does the return line still hook up the same? and will the plastic fuel line be OK under pressure rather than suction? Looking for best fix rather than cheapest. When messing with gasoline and 914's I have become a little gun shy.
TheCabinetmaker |
Apr 19 2004, 12:49 PM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I can take a pic, but ya can't see much unless you take it off. It's just a piece of sheet metal shaped with a bulge in it, and the pump is bolted to it on rubber shock absorbers. When I moved mine in my 73, I mounted it on the bulkhead forward of the tank.
Lo-Fi Version | Time is now: 27th September 2024 - 04:17 PM |
