We're Painted, Proof There really is a Car! |
andys |
Jul 18 2011, 03:15 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
Painted the car finally - I took two days to do the sealer, base, and clear (It took me nearly 5 hours just to mask and skirt, as I put the car on jack stands). Color is GT Silber. Used (very) $$$ PPG.
Scottyb, you were right about the amount of base. I used just under than 2 quarts for three coats (the cabin, engine bay, and inside both trunks were already done). PPG does not recommend reducing the clear, but every painter I talked to said to reduce it. Guy that owned the booth said to reduce the hell out of it, and as it turns out, that worked out really well. I started the initial color sanding with 1000 grit to knock it down before the clear got too hard. Managed to get about 3 1/2 corners of the car complete; then on to the doors, trunks, lid, and targa. I'll do final sanding and buffing after assembly (cause you never know what oops might happen!). Andys Attached image(s) |
scotty b |
Jul 19 2011, 08:28 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Nice job. (IMG:style_emoticons/default/first.gif) FWIW I reduce the hell out of PPG too. Usually 15-20 percent, but then again I even reduce thin ass Nason too (IMG:style_emoticons/default/unsure.gif) Might want to consider wet sanding and buffing the removable panels and body edges before assembly, It will make for a better job, Tape off all the edges when assembling to prevent the " oopses "
Lo-Fi Version | Time is now: 27th September 2024 - 12:17 PM |
