shifter, bushings |
shifter, bushings |
Randal |
Aug 1 2011, 10:45 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Who was making replacement bushings for the shift rod and transmission housing on a side shift?
Like all the bushings from the firewall to the transmission. Someone was machining them out of bronze if I remember correctly. Did those work better? J West was selling a kit that had all this stuff and more - if I could find it. (IMG:style_emoticons/default/drooley.gif) Or what is the best set up available now? |
Mike Bellis |
Aug 1 2011, 11:15 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
If you mic the rod, you can get a nice spherical bearing from www.mcmaster.com or ebay. Just match the ID. I swapped my front rod to a 3/4 OD rod and a 3/4 spherical bulkhead bearing. Mine is Oil-Bronze with a fitting to refill the oil.
Lo-Fi Version | Time is now: 27th September 2024 - 09:01 AM |
