Clutch Cable, Broke over the white roller ? |
jim_hoyland |
Sep 20 2011, 02:44 PM
Get that VIN ? Group: Members Posts: 9,418 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Any particular reason the clutch cable would unravel at the top of the roller ? Should the roller spin freely when reasembled ?
A few pics of what I'm looking at... (IMG:style_emoticons/default/smile.gif) Attached image(s) |
Chris Pincetich |
Sep 21 2011, 01:58 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
I just replaced my clutch cable after seeing the frayed bits sticking out at the roller. When I took it off, it was actually WORSE at the end just inside the housing. The cable bits broke at the friction point where the housing ends in a metal circle and were lumped up inside the housing, out of sight completely.
So, if you see any cable fray at all it is worth a closer look or quick replacement. I went with the Terry Cable version. (IMG:style_emoticons/default/beerchug.gif) |
jim_hoyland |
Sep 21 2011, 05:40 PM
I just replaced my clutch cable after seeing the frayed bits sticking out at the roller. When I took it off, it was actually WORSE at the end just inside the housing. The cable bits broke at the friction point where the housing ends in a metal circle and were lumped up inside the housing, out of sight completely. So, if you see any cable fray at all it is worth a closer look or quick replacement. I went with the Terry Cable version. (IMG:style_emoticons/default/beerchug.gif) Exactly same place where mine frayed and broke. Did you find foreign material in the wire too ? Seems like a boot could really protect this area----anyone seen one ? |
jcd914 |
Sep 22 2011, 02:14 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Seems like a boot could really protect this area----anyone seen one ? Originally there was a boot that goes on the end of the clutch cable where it mounts to the pulley bracket. It is seals the cable to the housing to keep dirt from inside the cable housing. A PITA to get over the threaded end of the cable. Jim |
jim_hoyland |
Sep 22 2011, 08:28 AM
Seems like a boot could really protect this area----anyone seen one ? Originally there was a boot that goes on the end of the clutch cable where it mounts to the pulley bracket. It is seals the cable to the housing to keep dirt from inside the cable housing. A PITA to get over the threaded end of the cable. Jim Anyone have a picture ? |
Lo-Fi Version | Time is now: 27th September 2024 - 11:05 AM |
