$10 paypal to someone willing to help diag my poor 2.0! |
bliggity |
Sep 29 2011, 07:36 AM
Newbie Group: Members Posts: 4 Joined: 10-July 11 From: GA Member No.: 13,297 Region Association: None |
I have a 74 2.0 with the factory fuel injection. I have replaced plugs, cylinder head temp sensor, electronic ignition/ coil, air filter, relocated fuel pump, fuel filter. All done about 300 miles ago. Car ran great for that 300 miles but now I have an issue I didnt want to have someone else fix but after a month of chasing I am clueless (IMG:style_emoticons/default/sad.gif) I can cold start the car and it will idle great and stay idling great 9/10 times. When I start to drive the car its fine for 30 secs to 2-3 mins then it will start to chug out and begin to die out, I can blip the throttle hard and it will rev for a few more secs then it will just die out. After it dies it will try to start but just cranks but never fires. It will then begin to have a strong smell of fuel. If I let the car sit for roughly an hour or more I can go crank it up and drive for 30 secs or so then it dies out. I have tried unplugging injectors to see if one is stuck open but I dont think so bc it is not constant. Let me know if anyone has any ideas. Please help, Im frustrated beyond belief (IMG:style_emoticons/default/driving.gif) I have messed with the ecu adjuster knob but does not help enough to fix issue. TIA for any help!
somd914 |
Sep 30 2011, 03:54 AM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
MPS are available through AA and Automotion, not cheap. You can check MPS resistance and for vacuum leaks to determine its health or lack there of.
This summer I fought a problem where the car would run for a while, sometimes just 3-5 minutes, sometimes longer. Turned out to be a broken wire on the CHT, that would be the FI wiring harness wire, not the the CHT lead. My assumption is as the wire heated and expanded, it would break the contact. It finally completely opened up which then made troubleshooting easy. An open circuit on the CHT will make starting difficult or impossible, and it won't run as the engine floods quickly. Also, do you have spark when this happens? As mentioned earlier, see the following renlist link for troubleshooting: http://members.rennlist.com/pbanders/djetparts.htm If it turns out to be your MPS, PM me, I have an extra that is not prime but works. |
Lo-Fi Version | Time is now: 27th September 2024 - 10:07 AM |
