Hazards not working |
uncle smokey |
Nov 6 2011, 08:50 PM
Newbie Group: Members Posts: 19 Joined: 4-June 11 From: PA Member No.: 13,157 Region Association: None |
I was working on some electrical issues on my dad's 73. I replaced the turn signal switch and the wiring as well as there were some old issues. New flasher too. All the turn signals work now but when I pull the hazard switch nothing happens. I tested the the terminal 15, iirc, and it is powered with the key on and works when the blinkers work, but goes out as soon as the hazard switch is pulled. This is happening on both of the switches I have. I guess its possible that both are bad, just wondering if anybody has any other opinions. All fuses are good too. Thanks.
Spoke |
Nov 6 2011, 09:12 PM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Here's a simplified diagram of the turn signal circuits. If the turn signals work then the flasher is good as well as the wires to the turn signal stalk.
Must be the wires to the flasher switch. Attached image(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 02:34 PM |
