Porsche 914 featured in Classic Driver Magazine, 146.000 EUROS For a six ????????????????????????? |
johannes |
Dec 16 2011, 09:12 AM
Club Porsche 914 France President Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
Here is the page they posted yesterday
http://www.classicdriver.com/fr/magazine/3900.asp?id=15621 (IMG:style_emoticons/default/chowtime.gif) |
toolguy |
Dec 17 2011, 11:43 AM
Senior Member Group: Members Posts: 1,273 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
At the risk of starting a controversy, about the door frame braces. . . I was concerned about that also in the beginning. . . So I carefully measured all the openings before lifting the chassis. . then I stretched .008 piano wire both laterally and diagonally across the body openings {side to side diagonally}. I secured the wire tightly to bolts for the seatbelts and door hinges so it was taught. . Then I lifted the chassis and watched which wires became tighter or looser. . . There was no perceptible change in any of the wires and all my pre lift measurements remained consistent. .
Also note the rotisserie has a lower steel rectangle beam tying the front to the rear, which has vertical gusset bracing. . . this turns the entire structure with the body into a rigid four sided box and helps prevent flexing also. . . Be assured, I was very careful and measured a whole bunch of times before I felt confident there was no flex. . . I guess this is what happens on a rust free, low mile body with no prior damage. . . I expected some change but didn't measure any. . . . And the proof was in the assembled body . . . . all the panels and doors aligned with door gaps even and all edges flush. . . . So this sort of makes me stop and think. . . the only place the frame can flex is between the door gaps. . and this is a full stripped shell. . . I guessing at around 800 pounds total and probably only around 100 pounds of that in the center floor section. . . . and what has more stress on bending the frame rails. . . ?? lifting a fully stripped chassis. . or some lively driving and throwing around a fully assembled car on a bumpy road. . . . . So if the argument is that you must have door braces to lift a bare chassis. . you'd think then you would also must have to install a braced roll cage to have a little driving fun. . . Plus it helped that this is an extremely low miles Southern California no rust car. . and I don't by any means suggest this can be done on other 914's without some careful planing and measurements. |
SirAndy |
Dec 17 2011, 02:25 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
So if the argument is that you must have door braces to lift a bare chassis. . No, that's not the argument. The point is that *most* 914s that end up on a rotisserie will have metal work done. Once you start cutting into the body to replace rusty panels, door braces are most certainly of value. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 10:25 AM |
