what did you do to your 914 today |
mrbubblehead |
Dec 17 2011, 08:07 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i just wanted to start a thread to see what you guys do day to day on your cars.
i'll start, about a month ago, i pulled my engine and trans to put in a new clutch. had the flywheel lightened and resurfaced. but what i didnt know is that i had to shim the little ball that the clutch arm rides on, after a resurfacing. so guess what i did today? yup, pulled the trans and put an extra washer under the ball. you have to goop up both washers to get it to seal because the threaded hole goes all the way thru to the inside of the trans. i also replaced the plastic cup that the ball rides in. the throwout bearing and its little plastic blocks were fine so i buttoned every thing back up. 5 hours total. i think this has been the cheapest repair yet on my car. $2.75 for the little plastic cup. what did you do to your 914 today? |
struckn |
Dec 19 2011, 02:50 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
Turned the Key to On and Fuel pump kicked in, EM Brake Light Flashed, Oil and Temp Light came on. Turned key to start and heard a click and everything went dead, tried Start again and nothing. Waited ten minutes and it did the same thing. Disconnected the Positive battery cable and removed the yellow tack wire from the Negative terminal at the coil, reconnected the Battery and she fired up and ran. Backed out of the garage and saw oil dripping from the Oil Filter. Put it up on ramps and took a oil filter wrench and gave it a 1/4 of a turn to snug it up. Better but still dripping. Coming down from above the filter. Only leaks when running. Drove around to my other garage and parked it for winter storage. Going to look for a good repair shop after Holiday and Income Taxes in the Spring and get everything fixed.
type47 |
Dec 19 2011, 04:33 PM
Turned the Key to On and Fuel pump ... and Income Taxes in the Spring and get everything fixed. Zach and Joe Sayre are in your area if you need a hand (hmmm, it's easy to volunteer someone else to help (IMG:style_emoticons/default/biggrin.gif) ) I finished the install of CFR SS fuel lines today after I received some parts from Tangerine. One "easy" job and I did it alone ('course the car has the engine out and is up on jack stands so that helped) |
Lo-Fi Version | Time is now: 27th September 2024 - 07:53 AM |
