OT: Type1 Bus Alt Q's |
Ferg |
Jan 5 2012, 03:18 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Helping a buddy, who is helping his boss out via phone (IMG:style_emoticons/default/blink.gif)
Type1 in a Split window has a few issues. In this pic, No current into battery when running. 12vdc at yellow/red terminal on top of alternator when running. Is there a external reg on these? Issue 2 is 1amp draw coming from battery with key off and out of ignition, traced to 8ga wire going to Starter. Bus is air bagged and he has no lift or ramps at the moment, if starter solenoid is going bad will it start to draw juice on its own? I suspect he may find other things powered there, once he gets a look at the starter... |
nathansnathan |
Jan 5 2012, 04:20 PM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
The regulator is usually on the firewall, it acts as a heat sink apparently. A modern alternator, though, it may be inside.
Lo-Fi Version | Time is now: 27th September 2024 - 09:07 AM |
