OT: Type1 Bus Alt Q's |
Ferg |
Jan 5 2012, 03:18 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Helping a buddy, who is helping his boss out via phone (IMG:style_emoticons/default/blink.gif)
Type1 in a Split window has a few issues. In this pic, No current into battery when running. 12vdc at yellow/red terminal on top of alternator when running. Is there a external reg on these? Issue 2 is 1amp draw coming from battery with key off and out of ignition, traced to 8ga wire going to Starter. Bus is air bagged and he has no lift or ramps at the moment, if starter solenoid is going bad will it start to draw juice on its own? I suspect he may find other things powered there, once he gets a look at the starter... |
904svo |
Jan 5 2012, 07:52 PM
904SVO Group: Members Posts: 1,124 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Those alternators have a build in regulator, to make it work you must wire the
terminal (male terminal) behind the battery lead, to the generator lamp for 12 volts, this is for the exciter field to get the alternator to work when the engine is running. Check out this site http://www.vw-resource.com/alternator_replacement.html |
Lo-Fi Version | Time is now: 27th September 2024 - 09:13 AM |
